pickaxe wrote:Stan, the water is from between 40ft to 100ft or so away. 150 ft is plenty. And next to no uphill, maybe 8ft at the extreme.
H20prospector, yeh, we could make a dent, for sure. Couldn't really say on the extrs 1/2hp. The inlet on your intake hose is limited to 1.5in.
Leonard, iffn we can get it together we'll call on your filmography skills. Could be our 15 minutes of fame?!
pickaxe wrote:H20, you can neck your inlet hose down and run a short section of 1.5in and its acceptable. Problem for you would be needing a 1.5in footvalve. A guy could run a 12in pump, if it were running a 1.5 footvale and hose.
You can set your highbanker right at your diggins and shovel right into it, or there is a large flat area right there and yes a 'barrow could work.
Users browsing this forum: No registered users and 9 guests
