Alternate pump idea
Alternate pump idea
Postby impfected » Sun Feb 21, 2010 7:31 am
Hi All,
I was joking with a friend about building our own dredge the other day when I came up with an idea.
Has anyone ever used the drive from a jetski to power a dredge? I mean, that pump has to produce some serious kick to sling those buggers as fast as they do and they are very cheap used ($150-300)
My thought was an aluminum boat with a jet drive and some sort of three way valve to switch the thrust from the stern (in travel mode) to the sluice/suction device in dredge mode. A self powered dredge of sorts.
Silly idea, but was fun to joke about high speed dredge and run, boat trips ;-)
Al
Re: Alternate pump idea
Postby killerkernrich » Sun Feb 21, 2010 10:44 am
I haved turned the jet around on my dredge after removing the suction hose, fire up the motor and let the jet of water push me and dredge loaded with gear...
killerkernrich
Postby CalGoldDredger » Sun Feb 21, 2010 1:53 pm
Woohhooo!!!! Fun.
Postby Hoser John » Mon Feb 22, 2010 7:54 am
:D I motorboat whenever possible--boobies that is-John :lol:
Postby CalGoldDredger » Mon Feb 22, 2010 12:12 pm
John- Of Course Image
Postby Reno badboy » Fri Jan 07, 2011 12:40 am
done that myself just to get back upstream!!!!! SSSSSSooooooooooo much easier!!!!! :lol: :lol: :lol:
Reno badboy
Postby micropedes1 » Fri Jan 07, 2011 8:54 am
Rigging the plumbing ain't the problem. Them suckers are all 2-stroke engines...they really suck up the gas. Not cheap! Plus, the enviros will pitch a fit at the oil slick that it leaves behind when you are running from a fixed position.
Postby gremlin » Fri Jan 07, 2011 3:41 pm
the new brp motors are cal aproved. there all 2 strokers. they use a envirofrendly oil.
