Directions to the Golden Optimist #1
Postby golden optimist » Fri Aug 06, 2010 5:20 am
If you have a GPS, you should find it at:
40 degrees 06.464 N
105 degrees 20.186 W
Going north out of Boulder on 36, it's 4-5 miles to Lefthand Canyon Drive. The Greenbrier Inn is right at the turn off. The claim is about 5 miles west from here. When you get to Buckingham Park, take the right fork. You will pass an area where people are unloading ATV's. Keep going. You will come to a hard left corner. There may be people parked on the right side of the road in a small canyon shooting. About 50 yards past that there will be a large pullout on the left. If it's after 9:00, you should see my red Ford Ranger with a dredge in the back. You've arrived. There is room for around 10 vehicles there.
If you go past it, 1/2 mile further up the road is the Ward/Jamestown junction and bridge. Turn around, come back down through the big cut and you are at the top of the claim.
Re: Directions to the Golden Optimist #1
Postby russau » Sat Aug 07, 2010 11:52 am
yep it sure would be nice to be there also but...................
Postby h20prospector » Sat Aug 07, 2010 5:49 pm
russau wrote:yep it sure would be nice to be there also but...................
Russ,
Due to other commitments, I wasn't able to make it to Douglas Creek, but Leonard's claim isn't that far from the house. I'll do some detecting for you.
Pat aka h20
Retired AF Veteran - 26 years
LDMA/GPAA/GPOC/PLP member
Ice & fly fisherman
h20prospector
