by h20prospector » Fri Oct 15, 2010 11:56 am
The problem I've encountered here in Colorado, is that if you can get a spot to work your highbanker (I've got a 3" Proline combo) is when I've got the unit in the water and working by myself, the unit is prone to tipping over, unless you have someone tending on top. I haven't had any problems getting water and material to run through the box as the 5.5 hp engine and pump assembly is fairly powerful.
h20prospector
Retired AF Veteran - 26 years
LDMA/GPAA/GPOC/PLP member
Ice & fly fisherman
