Dredge Nozzle insight
Re: Dredge Nozzle insight
Postby bill-costa rica » Wed Feb 06, 2013 5:57 pm
might not want to put the end of your retort in water ! if it sucks the water up into the retort it could ruin your day… besides that pretty cool.
bill/cr
bill-costa rica
Postby rivraton » Wed Feb 06, 2013 7:38 pm
bill-costa rica wrote:might not want to put the end of your retort in water ! if it sucks the water up into the retort it could ruin your day… besides that pretty cool.
bill/cr
Really?
Pretty much SOP:
rivraton
Postby Sierra Sam » Wed Feb 06, 2013 8:28 pm
Russau -
"Repurpose"
I like that. :shock:
Bill - :idea:
I'm careful to keep the tip just below the surface and no further, in an "effort" to minimize !!Kaaaahhh...POW!!! :lol:
Rivraton -
Thanks for the pic.
Postby Sierra Sam » Thu Feb 07, 2013 3:29 pm
Well, no more excuses -
My Jobes nozzle just arrived -
It's beefier than expected. That's a good thing.
The restrictor washer seems a bit lackluster, but then a tapered brass fire nozzle would be a bit much to expect I guess.
The inside weld is a bit sloppy, but again would be within mass production specs I guess. It is after all, a difficult place to weld.
Now the question begs to be answered, Should I weld the 1/4" rod around the nozzle's end, and should I weld a brace between the small jet to the larger pipe for support? After all, I do expect to be muscling this thing around in rocky places and even, I suspect, pry a few stones with it from time to time.
Postby russau » Fri Feb 08, 2013 4:27 am
no! id leave it just as you got it! i had a 2" and a 3" nozzel and they work fine just as is! i ended up selling them with some other equipment for fuel last year. yep, i agree about that sloppy weld(i weld also) that washer would have been welded prior to welding on the highpressuer pipe.so that should have been a smooth weld.unless your working blind(in muddy water)youll soon get a feel for useing that nozzel without anything welded to it that restricts any rocks from going up the tube! even with me 4 " dredge, i throw a lot of rocks that have that "size/look" about them that causes jams.
Postby Hoser John » Fri Feb 08, 2013 8:21 am
THAT UNGODLY LACK OF QUALITY SUCKS--hope the nozzle does with that lil' ol' pump your tryn' to use-John :?
Postby Sierra Sam » Fri Feb 08, 2013 10:40 am
Russau - The "inside weld I was referring to was the outside one holding little pipe to big pipe at the inside of the joint. Getting your tip in a wedge between the two can sometimes be "sticky", especially if you stop and start with your hood on. Since you weld I'm sure you understand.
I AM going to clamp a rod across the end just to minimize jams. it won't keep things from sneaking in lengthwise and turning somewhere along the way, but it will help a bit with the big stuff my little pump will have to be dealing with.
I saw this somewhere else (these particular pics are ripped from http://goldadventures.biz/my_equipment) and mentioned it to a friend who implemented it on his rig and he saw a BIG reduction in jams, so I figure I should follow my own advise. I noticed in these shots that the guy notched the end of the nozzle to keep the rod in place. This actuall looks a lot like a Jobes nozzle. (no endorsement intended)
John - Aside from the aesthetics of the welding, this is a lot heavier construction than expected. The welds appear to be solid, just not pretty. And welders appreciate other welders who have the skill to lay down a nice pretty bead. :)
And yeah, I hope it does what I want it to do as well. :roll:
Postby Hoser John » Fri Feb 08, 2013 3:37 pm
The only thang crappier than that nozzle is the insipid idea of EVER restricting a nozzle in any way with a bar. That po' tiny nozzle is already knurled down to prevent jams so absolutely nuttn' ever needs to be done--mo' better pump would help though. I've kept pics you posted so when folks ask about their quality of fabrication I can utilize as examples of what NOT TO BUY :shock: sorry man but that's jus' sooooo bad--- :lol: John
Postby bill-costa rica » Fri Feb 08, 2013 4:53 pm
you just don’t want to listen !!! ok, take that pos and do what you want…. we will see how well you do. what a frickin joke. I’m done , have a good life. :?
bill/cr
bill-costa rica
Postby golden optimist » Fri Feb 08, 2013 5:32 pm
I tend to agree with John. Don't weld anything over the nozzle. Just control your feed. If you have to put anything over the nozzle, 1/4" hardware will completely do away with jet plugs. It just won't move any material.
