Hydro Force Suction Nozzle
Re: Hydro Force Suction Nozzle
Postby Bluebeard » Sat May 25, 2013 7:16 am
When the it first came out I was using a 3" hydroforce on dry land. I had a creekbed I was working to try to get down to bedrock. I modified the set up where I had a P180 running the nozzle, but about 6 feet upstream of the nozzle I had a "helper jet" which was an inline power jet which was run by another P180 then the suction hose went to a sluice box. With that set up, I literally dug a 10 foot deep hole on dry land with the hydroforce. The cool thing about the hydroforce, is you are always working about a 6" deep pool of water- as long as you keep the pool 6" deep, it doesn't spray back in your face, and you can keep going down. I never got down to the bottom of the creek at 10 feet as the bedrock kept angling down and winter set in and so I was done for the season.
Tom working the hole 3 copy.JPG (98.76 KiB) Viewed 2170 times
Tom Using the Hydroforce copy.JPG (99.26 KiB) Viewed 2170 times
Bluebeard
Postby russau » Sat May 25, 2013 3:12 pm
where theres a will, theres a way!
Postby dickb » Sat May 25, 2013 6:13 pm
I kind for figured that a hydro force with a high banker and a recir settling pond would be a slick way to work a high bench deposit. No heavy machinery and no POO, but it would be a lot easier than pick, shovel and a sore back. Just thinking out loud. :D
Postby russau » Sat May 25, 2013 6:27 pm
yep just about anything is EZer than a pick-n-shovel! i think(for me anyway) that Leonards new approach is just what i need,and the way ill be approaching mining from now on!what do you think Leonard??
Users browsing this forum: No registered users and 30 guests
