by Joe S (AK) » Sat Apr 10, 2021 11:39 pm
In the mid 60s I learned about water dowsing and learned to use the forked twig with absolutely no effort. In fact, the second or third time I used the green peach branch I was going to really test this phenomenon - because it was just too simple to be real.
I, with my father, brother and other adult guys were attempting to locate a new site to re-dig a failing old well (the reason to be using the dowsing in the first place). It was not a trivial matter - wells on that Pennsylvania mountain top would often go down 3,000 plus feet, and sometimes simply came up dry. The branch "told me" a spot six feet from the old well was the hot location and that spot was staked. Then, to test the dipping twig I clamped down HARD on the forked twigs with both hands and tried with all my 18 year old's hand strength to force the twig back up from diving at that spot. I was strong back then and I rotated both locked on hands to twist the stems against 'the force' and to bring the diving down tip back up to level. I clamped down with all my strength and twisted both "Y" branches in a do-or-die battle.
No, I couldn't bring the vertical tip back up - and then the adults joked with me as they took the forked peach branch to keep looking, themselves. Suddenly it got really quiet. The bark on the branches where I had my "Vulcan Death Grip" had twisted and separated from the wood underneath. The bark was completely loose and not attached to the wood under any more. Scary. The stake, 6 feet from the old well stayed in place.
Oh, before I forget - the well driller came to dig the new well and knew that there was a lot of money to be made on that mountain. He sauntered over, full of confidence and experience and asked where we all wanted to start the new well project. The adults all pointed to the stake that had been put in the ground six feet from the old well which was where I had twisted the bark off the branch. The well driller laughed, since the old well was clearly visible, and then, looking at all the serious faces around he stopped laughing. In a short while he was set up over the stake and planning how to spend the money from the "Gonna be a dry one."
At 18 feet he hit water. "Just surface water" he said - and so he continued drilling. At 24 feet he was asked to stop. He re-affirmed that surface water would just run out the minute it started being pumped - and to prove it he set up his truck mounted pump (the big one) and began pumping. 2, 3, 5, 10, 25 and then 30 minutes of continuous pumping could not pump out that well. DEAL DONE. 57 years later and the well is still producing.
A couple of years later in Alaska I was working with the Natural Gas Company running gas lines to homes and businesses. We had Fischer "M Scopes" to find the gas mains --- however --- once in a long while the M Scopes would just not work. The first time that happened my crew chief went to the truck and brought back two brass brazing rods, bent them into a 90 degree angle and handed them to me. (he didn't know about the peach branch bark) Those brass rods worked 100% right from the git-go. They worked so well that at times, just for fun, we would use the rods instead of the M Scope.
Over the years I have found water, underground pipes, buried electric wires, old ditches, drain tiles, plastic septic lines and, of course, overhead power lines. Maybe some day soon I'll try an experiment or two with Gold.
I have heard skeptics in the past speculating that the rods are 'picking up' magnetic "flux lines" and that is all they do. I have kept my mouth shut about the fact that I use brass rods that are absolutely unaffected by magnetism.
- Joe -
