miners moss
miners moss
Postby joxer76 » Wed Jul 21, 2010 6:25 pm
a question about miners moss. If i were to use it in my sluice box, would i put it on top of the carpet or eliminate the carpet altogether and replace it with the miners moss? thanking all in advance.
joxer
joxer76
Re: miners moss
Postby trick » Wed Jul 21, 2010 10:03 pm
Replace carpet with moss, put ribbed matting under the moss. Hope this helps.
trick
Re: miners moss
Postby russau » Thu Jul 22, 2010 4:47 am
then cleanup often untill you know how long itll be before you need to cleanup your sluice without it loading up on you.
Re: miners moss
Postby Hoser John » Thu Jul 22, 2010 6:00 am
Eliminate the moss and keep the carpet-John
Re: miners moss
Postby h20prospector » Fri Jul 23, 2010 11:42 am
I've got a Keene A51 sluice. Should I take the green carpet and black mat at the top and replace it all with deep V mat?
Retired AF Veteran - 26 years
LDMA/GPAA/GPOC/PLP member
Ice & fly fisherman
h20prospector
Re: miners moss
Postby Dawgmining » Fri Jul 23, 2010 11:00 pm
moss works good if the riffles are scouring ,,otherwise use the carpet
John Adams
Dawgmining
Users browsing this forum: No registered users and 38 guests
