Hydrolic mining?
Hydrolic mining?
Postby Geo-George » Fri Aug 27, 2010 4:07 pm
I know of the hydrolic mining of the past and that it was banned in Calif.
My question is,....
Is there any law against using water pressure from a 1 1/2" line to remove material from a sand/gravel bar that is located within a stream? The stream divides and goes around both sides of the bar. :?
Re: Hydrolic mining?
Postby Dawgmining » Fri Aug 27, 2010 5:58 pm
George`, :D your toilet is a hydralic devise, ask your ? to Reno Cris here.... http://www.nuggetshooter.ipbhost.com/
otherwise I have never been aressted for somthing I was not caught doing :?: :?: yous from Nevada so is Chris
Myself HANDS and PANS Below The water level
;) ;) ;) ;) ;) ;) ;) :lol: 8-)
John Adams
Dawgmining
Postby Geo-George » Fri Aug 27, 2010 8:35 pm
Never seen a toilet used to prospect for gold. :roll:
I'm from Nev., but my claim is in Calif.
I was hoping for a serious answer. :(
Postby rivraton » Sat Aug 28, 2010 12:06 am
Geo-George wrote:Is there any law against using water pressure from a 1 1/2" line to remove material from a sand/gravel bar that is located within a stream? The stream divides and goes around both sides of the bar. :?
I'm not sure exactly where it is in the regs., but you are restricted to a 3/4" MAX hose diameter for washing / flushing.
rivraton
Postby Geo-George » Sat Aug 28, 2010 5:26 am
Thanks rivraton, I can do that.
I wasn't sure if it would still be concidered "high banking", but I believe I'm O.K. in that respect due to the fact that I will be working within the stream. ( below the high water line )
Postby Hoser John » Sat Aug 28, 2010 5:37 am
There is NO size restriction and your absolutely right about BELOW the water line BUT just ask GO what happens when ya put dry into wet--plenty a trouble of that you can bet. BUT(gotta luv'm) like the man Dawg says-ifn' ya ain't seen ya ain't done squat and leave the panty twisting moralistic judgements to lesser men :twisted: party on and tons a au 2 u 2 -John
Postby Geo-George » Sun Aug 29, 2010 6:58 am
Luckily, the sand and gravel are moist. Water is seeping under the bar in several places. The bar is lying on bedrock. I'm using the hose to wash material into a pile onto bedrock, shoveling into screens, then running through my sluice. Seems to be working just fine. Spent all of Sat. working the bar and am having good results. 8-)
I do wish I could legaly use a dredge though. :evil:
Postby Seattle-times » Mon Aug 30, 2010 3:37 pm
You just need to have the right equipment:
http://video.yahoo.com/watch/4646256/12418751
Seattle-times
Postby Geo-George » Mon Aug 30, 2010 5:05 pm
That's a pretty cool unit, Calif would still concider it a "Suction Device" though. :(
Postby Tanqd » Mon Aug 30, 2010 7:44 pm
Dredge smedge. That machine is a dryland cobble re-locator. You'd be fine!
Nice to hear from you Rex. Fired that thing up lately? Married yet?
Tanqd
