On site oil changes, Dredge Engines.
Postby Rod1874 » Thu Oct 21, 2010 3:06 am
I have found a product that may be of interest to gold dredgers, makes oil changes alot easier!
http://www.perr.com/drainzit.html
I have ordered one to suit my Honda GX 160 & GX 200 plus my EX 21 Subaru.
Rod :D
Rod1874
Re: On site oil changes, Dredge Engines.
Postby russau » Thu Oct 21, 2010 5:39 am
$13.95 plus shipping. HUMMM?
Postby Hoser John » Thu Oct 21, 2010 6:29 am
Rubbing vibrations from dredge bouncing rubs them through. I use metal extension with a simple on/off valve on it and good to go. ALWAYS use a simple drip pan(al cookie sheet) under your dredge engine when ya mount them to the frame and the environutz and bureauratz leave ya alone-John :D
Postby gremlin » Thu Oct 21, 2010 7:21 am
looks like you can get a drain valve at walmart that looks the same in the post. or at napa that is a quick connect.
http://www.napaonline.com/Search/Detail ... 0261481519
Oil Drain Valve
Product Line: NAPA Small Engine
Part Number: SME 2575514S
Price: Price
Unit 12.69 Each
Warranty 2 Year Limited on Manufactures Defect in Material or Workmanship
Attributes Oil Drain Valve Hose Size : .5"
Oil Drain Valve Operation : Twist & Pull To Open, Push & Twist To Close
Oil Drain Valve Thread Size : 3/8"-18 NTP
