Do they make a multi screen trommel? Like 2 or 3 tubes inside each other that has a separate output for each size classified. I was thinking you could feed each of those outputs to sluice boxes especially set up for that size.
Just thinkin
Rick
Joe S (AK) wrote:Geo,
In a single drum setup shouldn't the slurry go over the smallest mesh screening first (with a 90 deg to the side sluice) and then the second, larger, screening going 90 deg to one side or the other. Then the washed oversize should discharge from the bottom end of the drum?
If the larger screening is first, an entire second screening has to be made of that slurry to get the smallest undersize. That's a whole lot more work (with more things to go wrong) than allowing the rotating drum to do both cuts one after the other with a space between.
Hoser John wrote:Process all screened oversize materials or you will be sorry. The 1/2 million $$$ Chicken creek nugget that was found whilst dozing a disguard pile into the creek is a prime example. John
Users browsing this forum: No registered users and 31 guests
