I've discovered a problem with some of my gold.
Postby cowboy444 » Sat Apr 09, 2011 3:16 pm
I built a webpage so you can see the pictures of the problem and a link to e-mail me if you have a solution.
http://www.cowboy444.com/Oregon%20Gold/index.html
Thanks for any help rendered.
cowboy444
Re: I've discovered a problem with some of my gold.
Postby Gold Seeker » Sat Apr 09, 2011 4:12 pm
Sent you an email, I hope the suggestion helps.
Postby Joe S (AK) » Sat Apr 09, 2011 6:23 pm
Disregard the "Alcohol smell". Add water, a small bit of soap and pan out as usual.
Postby russau » Sun Apr 10, 2011 5:58 am
or dump whatevers there and fill it with rubbing alcohl
Postby Geo-George » Sun Apr 10, 2011 6:34 am
Am I missin' sumpin'?
I don't get it, what is the prob? :?
Postby cowboy444 » Sun Apr 10, 2011 9:46 pm
Geo-George wrote:Am I missin' sumpin'?
The problem is that everything was black. I've put it in Distilled white vinegar and the gold is coming clean. There's still a couple of clumps of black stuff but I'm hoping that too will change back to gold.
cowboy444
P.S. Thanks to Megan, Kurt, and Skip for e-mailing and guiding me back to clean gold.
cowboy444
Postby DJR » Wed Apr 13, 2011 10:32 am
If it turned black then more then likely it is not gold.
Gold don't do that.
Only the Educated are Free.
Epictetus, Roman philosopher
DJR
Postby Joe S (AK) » Wed Apr 13, 2011 7:08 pm
Probably Brass then, discolored by the Oxygen in the fluid.
Postby swizz » Thu Apr 14, 2011 4:39 am
Joe S (AK) wrote:Probably Brass then, discolored by the Oxygen in the fluid.
Brass is a man-made alloy (copper + zinc), not a naturally occurring element or mineral.
No eternal reward shall forgive us no for wasting the dawn
swizz
Postby Joe S (AK) » Thu Apr 14, 2011 7:53 am
Swizz,
Yes, thank you, but we all knew that. :mrgreen:
We all also know that a lot of (man made) brass has been passed off as (non-man made) placer Gold in the past. :roll:
Not hard to do when fresh, what with rock tumblers making brass chunks look as though it was just found in the sluice box. :twisted:
After a while the brass gets a dark coating of Copper Oxide which would easily explain the "Black Gold"
