You HOT???
Re: You HOT???
Postby Hoser John » Wed Jul 27, 2016 5:38 am
:o Now the main water lines blew to top off the 114 at my house yesterday .Air conditioner about killed itself trying to keep the place cool. Ya all take care out there as they say we're gettn' HOTTER :shock: . John
Re: You HOT???
Postby russau » Wed Jul 27, 2016 6:10 am
John keep your condenser on that A/C clean and when it gets too hot spray the condenser with your hose to help it condense the hot liquid to gas so it can do its job! OR jump a flight to good ole Misery and I got you covered until the heat goes away!
Re: You HOT???
Postby russau » Thu Jul 28, 2016 2:33 am
Well it appears that the heat wave is slowing down abit! Well atleast it appears that way here in Misery! hope it keeps going down!
Re: You HOT???
Postby Hoser John » Fri Jul 29, 2016 6:00 am
115 yesterday....calling for 116 today and nothing under 100 in sight on the 10 day either :shock: summer from hell-John
Re: You HOT???
Postby russau » Fri Jul 29, 2016 7:46 am
John with that temp of heat for that kind of duration , Id expect to see some "earth movement" comeing your way and probly see some around the Country also! Im surprised to NOT see some already!
Re: You HOT???
Postby Hoser John » Sat Jul 30, 2016 5:47 am
Took clean brite to outside condenser as water doesn't touch sticky pollen. Jus' trying to get through this mess as cooling down to 110 today they say as 115 yesterday SUCKED as smoke blows in now from fires......John
Re: You HOT???
Postby russau » Sat Jul 30, 2016 9:44 am
yep I use a product called "coil cleaner" to brighten the fins to gain my condensing / heat transfer ability back IF needed. some of these products actually eat away at the alum material and could cause a leak if used to much or not sprayed off soon enough!
Re: You HOT???
Postby Hoser John » Sun Jul 31, 2016 6:10 am
amen Russ, my buddy Chuck is a air tech for 30+ taco bells and he did it. Caustic soda is ingredient and it LOVES aluminum for breakfast. He's coming back with the indoor condenser cleaner in a few days-good man-great friend-maniacal miner as human forklift with more muscle/energy than any 3 men should have...great partner-John
Re: You HOT???
Postby golden optimist » Sun Jul 31, 2016 6:52 am
It's been tolerable here. High 809's, low 90's. AC working good, life is great. I keep thinking about how nice it would be at Douglas Creek though.
Re: You HOT???
Postby Jim_Alaska » Sun Jul 31, 2016 6:58 am
Hoser John wrote:good man-great friend-maniacal miner as human forklift with more muscle/energy than any 3 men should have...great partner-John
Can I borrow him John? I need a young, strong partner. Strength is all but gone for rough work. Legs don't work well at all. No stability on cobbles or rough ground. Its no fun face down in a blackberry patch, or tearing up your knees.
