my favorite gun made mo bettah
Postby eightymesh » Thu Dec 23, 2010 5:43 am
eightymesh
Re: my favorite gun made mo bettah
Postby Leonard » Thu Dec 23, 2010 7:08 am
Looks like a great snake gun.
Postby CalGoldDredger » Thu Dec 23, 2010 11:34 am
Yes, very nice. :D
Postby foundit » Thu Dec 23, 2010 11:51 am
Freakin Sweet, I,m gettin one.
foundit
Postby Leonard » Thu Dec 23, 2010 2:42 pm
See snake, blast away until the clip is empty! Reload and repeat if necessary! What could be better!
Postby CalGoldDredger » Thu Dec 23, 2010 8:24 pm
Is it too late to revise or update my Santi list ????
Postby russau » Fri Dec 24, 2010 6:19 am
CalGoldDredger wrote:Is it too late to revise or update my Santi list ????
hahahahaha well your paying for it anyway! go ahead! you desearve it!!!
Postby Plumas » Fri Dec 24, 2010 6:44 pm
Too bad those of us living in California will never be able to own one.
Plumas
Ah ain't no flatlander!
Plumas
Postby russau » Sat Dec 25, 2010 5:49 am
if MS-13 can have automatic weapons,booby-traps,meth plants,and kill people, then why cant you have a pistol to defend yourself?
Postby Plumas » Sat Dec 25, 2010 9:09 am
Russ
We can have pistols alright.. Well, some pistols anyway. This one will never make it to our DOJ's "approved handgun list" (Must be on the "list" to be legal to sell new in CA.) You see, California considers this pistol as a short barreled shotgun and under no circumstance, can one even be brought or imported into the state. It's actually a felony. Yeah, go figure. Check it out.
Penal Code 12001
(f) Nothing shall prevent a device defined as a "handgun," "pistol," "revolver," or "firearm capable of being concealed upon the person" from also being found to be a short-barreled shotgun or a short-barreled rifle, as defined in Section 12020.
Penal Code 12020
(c)(1) As used in this section, a "short-barreled shotgun" means any of the following:
(A) A firearm which is designed or redesigned to fire a fixed shotgun shell and having a barrel or barrels of less than 18 inches in length.
(B) A firearm which has an overall length of less than 26 inches and which is designed or redesigned to fire a fixed shotgun shell.
(C) Any weapon made from a shotgun (whether by alteration, modification, or otherwise) if that weapon, as modified, has an overall length of less than 26 inches or a barrel or barrels of less than 18 inches in length.
(D) Any device which may be readily restored to fire a fixed shotgun shell which, when so restored, is a device defined in subparagraphs (A) to (C) inclusive.
(E) Any part, or combination of parts, designed and intended to convert a device into a device defined in subparagraphs (A) to (C) inclusive, or any combination of parts from which a device defined in subparagraphs (A) to (C), inclusive, can be readily assembled if those parts are in the possession or under the control of the same person.
(21) As used in this section, a "shotgun" means a weapon designed or redesigned, made or remade, and intended to be fired from the shoulder and designed or redesigned and made or remade to use the energy of the explosive in a fixed shotgun shell to fire through a smooth bore either a number of projectiles (ball shot) or a single projectile for each pull of the trigger.
Penal Code 12276.1
(a) Notwithstanding Section 12276, "assault weapon" shall also mean any of the following:
(8) Any shotgun with a revolving cylinder.
The last code section above further prohibits pistols like the Taurus Judge or Thunder 5 by classifying them as assault weapons because they are considered to be shotguns with revolving cylinders. Absolutely verboten in CA. Like felony-go to prison forbidden.
Sucks don't it? Merci le liberals.
Plumas
Plumas
