Wanted P90 Water Pump Seal Kit
Postby DJR » Tue Feb 21, 2012 1:39 pm
I need a "
P90 Water Pump Seal Kit" anyone have one for sale?
Only the Educated are Free.
Epictetus, Roman philosopher
DJR
Re: Wanted P90 Water Pump Seal Kit
Postby rivraton » Tue Feb 21, 2012 2:51 pm
rivraton
Postby Gold Seeker » Tue Feb 21, 2012 4:02 pm
You can get anything you need for your pump from Armadillo Mining Shop, there seems to be a problem with the webpage that has all the pump parts, but a call to them will get you what you need if you can't find it anywhere else.
http://armadillomining.com/cgi-bin/imca ... cgi?cat=41
They have a contact link at the top pf all pages.
Postby russau » Tue Feb 21, 2012 6:12 pm
yep i also found that these seals can be bought cheaper at industrial supply houses online or just bring your pump/seal to a hydrolic repair shop or a pump repair shop. or just get online with Keene,Proline or Armadillo mining supply. i keep spaire seals for my pumps and the tools to replace them in my trailer just incase.
Postby DJR » Wed Feb 22, 2012 8:14 am
russau wrote:yep i also found that these seals can be bought cheaper at industrial supply houses online or just bring your pump/seal to a hydrolic repair shop or a pump repair shop. or just get online with Keene,Proline or Armadillo mining supply. i keep spaire seals for my pumps and the tools to replace them in my trailer just incase.
Is there a way to figure out what I need to get them online, without taking the pump apart. I just want a spare and money is very tight right now.
Thanks for any help
DJR
Postby russau » Wed Feb 22, 2012 2:54 pm
yep moneys tight for me all the time. you need the seal specs. and without takeing it apart and measureing it, i dont know how you could identify what seal you have.and if i didnt buy from a dealer, i couldnt call them and ask for their help identifing what seal i would need. but i dont think that seal is expensive at all.atleast back when i bought mine from Armidillio years back.
Postby DJR » Thu Feb 23, 2012 8:19 am
Thank you sir.
I appreciate the help.
DJR
Postby rivraton » Fri Feb 24, 2012 1:04 am
Is this P90 on a 2 stroke or 4 stroke?
If it is on a a 4 stroke eng. John Crane P/N JC-601/WPS2 should fit...(Shaft Seal Type 304, Industry #601, .750" Shaft, 1.575" Seal OD)
If it is on a 2 strole eng. I can't help you...
rivraton
Postby Hoser John » Sat Feb 25, 2012 8:19 am
:D KING BEARINGS IS STOCKING THEM ALL :D
Postby DJR » Sun Feb 26, 2012 7:25 pm
rivraton wrote:Is this P90 on a 2 stroke or 4 stroke?
It's the four stroke that came from Keene. Thanks for the help
DJR
