by russau » Tue May 15, 2012 4:11 am
buy some ABS plastic and make it yourself! mlight in weight/priced at 1/2 of alum. EZ to form and use the ABS adhesive that NEVER lets go!ive made three of them for my dredges and they are holding up to my abuse!if you form the edges by bending the ABS cold, do it very slowly or itll crack.then apply a small amount of ABS adhesive to that edge for some extra strength(the glue will dissappear when dry) or heat the edges and bend it had hold them inplace untill it cools a little,then itll retain its shape.a sheet of 1/8 ABS is about $62. comparied to a sheet of alum at twice that!
