almost new Keene 6" twin honda 9's w/263 + drysuit +++
Postby misterbigtoe » Wed Mar 10, 2010 11:20 am
Not planning to dredge again any time soon and other priorities have prompted me to sell some of my little remaining personal property. The squirrels in the park are safe for a little longer!
COMPLETE....TOP OF THE LINE.... STOCK Keene 6" Dredge with Twin 9 HP Hondas, 263 compressor. Stainless reserve tank, 3 stage sluice, 20' suction, dual pressure and intake hoses, footvalves, blaster nozzles, some prybars and slide hammers, etc..... All stock, and nearly new. Only things missing are the air filters that a dumass black bear ate from the riser. Bought it in 2007 from AMDS, used it only that season. Fewer than 100 running hours and in garaged storage since then. Sorry, no air lines, regulator or mask included as mine are stranded in the bush. Runs and operates as new.
I am including my DUI shell drysuit and the superheavy DUI 2 piece insulating undergarment. Size is suitable for an individual up to 6'3" and 275lbs. It fit Joe S (AK) just fine when he wore it a number of years ago ;) Used two seasons. Might need new wrist and neck seals by now or might not. Used a wet suit the last couple seasons I dredged in Alaska.
Also including one of the GOOD Cast hand winches in good condition with good undamaged cable and a 12000 lb snatch block.
Will answer all questions
Located for pick up in the midwest. Best offer over $ 5000.00 rec'd by March 17. Save BIG BUCKS over buying new.
misterbigtoe@yahoo.com
more pictures available
misterbigtoe
