under water metal dector
Postby barney-mi » Thu Nov 03, 2016 10:19 pm
Don't have any idea how much a used one would be,I lost my class ring many years ago and was thinking about inquiring about a detector n see if I can find it,maybe someone has already found it but it would be fun to look for it. It would be in about 3ft. of water in a lake here in Mich. don't want to spend an arm & a leg for one. any input would be greatly apreached. Barney-mi :)
barney-mi
Re: under water metal dector
Postby russau » Fri Nov 04, 2016 2:47 am
Barney any MD should work fine for that as long as you don't get the control box wet. OR why not ask some metal detecting club if they could find it.
Postby barney-mi » Fri Nov 04, 2016 6:56 am
I have a md but didn't know if it would work under water, I could write the manufacture and get a extra pole to make it longer. ok thanks Russ have a nice day :)
barney-mi
Postby Hoser John » Sat Nov 05, 2016 6:18 am
WHAT MD DO YOU HAVE AS NOT ALL COILS WATERPROOF....go to kellyco.com and see if it is or post make/model as very knowledgeable folks here will help but just md tells nuttn' John
Postby barney-mi » Sat Nov 26, 2016 6:07 pm
Finally got some time, ok I have a white's mxt tracker E-series with an eclipse 950 sn# 2207-0308-144
mxt (e-series)
800-0308
that's all I could find out on the dector. any help finding out if I can use the head under water or what head would work on this dector would be much appreciated. thanks in advance Barney-mi
barney-mi
Postby barney-mi » Wed Nov 30, 2016 11:10 pm
No one can help me with this ??
barney-mi
Postby LipCa » Thu Dec 01, 2016 12:17 am
I wish I knew the answer... this is the only way I know to help you..... http://www.detectorprospector.com/forum ... tor-forum/
You'll get the answer there.
LipCa
Postby golden optimist » Thu Dec 01, 2016 9:03 am
If Matt Matson passes through I'm sure he'd have an answer.
Postby barney-mi » Thu Dec 01, 2016 9:16 am
Ok thanks guys
barney-mi
Postby Matt Mattson » Fri Dec 02, 2016 3:17 pm
The coil is supposed to be waterproof - but nothing else is so be careful. It would be a shame to lose such a great detector, if you can get your hands on a loaner underwater unit, that would really be the way to go.
Matt Mattson
