Wanted--dredge motor
Postby micropedes1 » Fri Jan 28, 2011 8:44 am
Am building another dredge. Looking for motors with 1 inch threaded shaft (for p280 pump). Prefer Honda or Briggs, but will consider others.
I know...whole dredges for sale on Craiglist, but I prefer my own build.
Re: Wanted--dredge motor
Postby russau » Fri Jan 28, 2011 11:35 am
i cant help you but what horse power are you looking for?
Postby micropedes1 » Fri Jan 28, 2011 12:36 pm
Russ, I don't think that they make a 6.5Hp with a 1 inch shaft, although I would prefer it as far as weight is concerned. I might could fashion an adapter on my lathe for the smaller motor, but it is not really economical.
I guess it is gonna need to be 8-9 Hp. Might not have to be threaded. I can change threaded impellers to fit keyed shafts, but it's a pain. (it helps to own a machine shop)
Postby dickb » Fri Jan 28, 2011 4:03 pm
Why not make a keyed to theaded shaft adapter and put spacers between the motor and pump!
If you have access to a lathe, you should be able to make it out of SS reasonably easy.
Only problem might be broaching the keyway into the adapter.
Good luck. :)
Postby CalGoldDredger » Fri Jan 28, 2011 4:19 pm
Too Late! Should of ask me two weeks ago had an almost new Honda 8 HP with a one day of run time, was missing the pump (sold it seperate) but still had the angled T-80 mount and the Keene base plate.
Horse traded with my uncle for a plasma cutter. :D
Postby russau » Fri Jan 28, 2011 4:55 pm
i do like them P cutters!!!
Postby micropedes1 » Sat Jan 29, 2011 7:34 am
Yeah, they are sweet. I have a 100 amp Hypertherm in the shop that cuts 1" steel plate almost like drawing a line with a pencil. We don't much use a cutting torch anymore.
Building an adapter to go from 3/4 to 1 inch shaft is not really a good idea, adapter ends up being too thin. Better to TIG the threaded impeller closed. Then redrill as a keyed impeller.
Postby Hoser John » Sat Jan 29, 2011 7:42 am
sold 2 last week and the last one yesterday as newbies buying every ungodly hunka piece a junk for sale from anyone and everyone--insanity rules 8-)
Postby CalGoldDredger » Sat Jan 29, 2011 10:35 am
Let them go and tear it all up, yes, makes for an interesting predicament. :twisted: :lol: :twisted:
Postby russau » Sat Jan 29, 2011 12:33 pm
if im not mistaken John Adams had some impellors that he posted here or overon 49er mikes site.
